IMO, you should choose to minimize galvanic action.I've always used bronze, but I noticed the zinc was cheaper. Is there any reason not to use the zinc? Thank you.
The clamps you are calling zinc are just plated with or hot-dipped in zinc (i.e. galvanized). The base metal is likely iron or steel.
I don't know what they're made of, but some of the "zinc" grounding clamps that I see are really light....too light to be steel or iron.
Leads me to believe that they are 100% Zinc.
Could be wrong though.
steve
Perhaps there are zinc only clamps. Perhaps, and quite likely the light, inexpensive ones are made of the so-called pot metal but they can be called zinc because it is the alloy element of highest content.
When I started to write my comment I had "are likely to be" iron or steel, and even then I should have wrote "the better ones"...
...but somehow neither made it into my now unedittable post![]()
While I give creedance to your comments, I do consider them somewhat biased towards the products you take part in, either directly or indirectly as a manufacturing representative. It is not my intent to berate quality manufactured goods. However, you have no control over what products do make it to market with or without UL approval.:roll: "Pot Metal"? If a clamp or fitting has a UL or CSA bug on it, it is highly unlikely that it has been made of an inferior zinc alloy. The main reason is that it would never pass the UL tests to become listed in the first place. My point is not all zinc die castings are created equally.
Pot metal is typically an alloy of Tin, Copper, Zinc and Lead. Most Electrical fittings made of Die Cast Zinc is a special grade of "Zamak" - not pot metal. We use an ASTM B86 certified grade of Zamak 7, which helps us guarantee the production quality of our products. However, you could still use the best raw materials on the planet, and if the manufacturing process is not controlled, there will be quality problems such as hidden porosity, brittleness, or excessive flash. Unfortunately, many competitors have offshored these products/processes and are less concerned about the raw material quality and resulting manufacturing quality. This has absolutely given zinc die castings a "black eye", and continues to be a problem for many electricians in the field.
With regards to the DC zinc clamps, if they are listed then they meet the same spec as the Bronze versions - UL467. The only exception is that they cannot be directly buried. In many cases they are absolutely suitable for indoor/dry applications, and thats what they are listed for, and are typically slightly less $ than the Bronze version.
UL467 is mainly concerned with the bonding and current carrying capability of the clamp. There is no separate listing for black pipe, copper pipe, rebar, or brass gass fittings. However, there is a proposal to have a separate fit test to list a clamp suitable for use on the brass CSST gas fittings. As far as I know, the UL specification has not yet been revised.
So, if a clamp is listed to UL467, it will work in most applications where it fits properly, can be tightened sufficiently, and has conductivity with the item its clamped on (i.e. scrape off that paint!).
Pot metal is a slang term that refers to alloys that consist of inexpensive, low-melting point metals used to make fast, inexpensive castings. There is no scientific metallurgical standard for pot metal; common metals in pot metal include zinc, lead, copper, tin, magnesium, aluminium, iron, and cadmium. The primary advantage of pot metal is that it is quick and easy to cast. Due to its low melting temperature no sophisticated foundry equipment is needed and specialized molds are not necessary. It is sometimes used to experiment with molds and ideas before using metals of higher quality. It is sometime referred to as white metal, die-cast zinc, or monkey metal.[1] Examples of items created from pot metal include toys, furniture fittings, tool parts, electronics components, and automotive parts
steve
I don't know the opinions of others in particular, but in my mind, having a NRTL bug on the product does not necessarily mean it is a quality product. All it means is that the part passed certain tests which were implemented to safeguard practicable usage of the product as intended. To me, that may guarantee of a certain level of quality... but yet could be far from the best quality...
All I am saying is that "if" a die cast zinc product has a UL/CSA/ETL bug on it, it will have passed the required listing tests stated in the applicable UL specification. ...
But then we enter into the realm of economics.... and a whole new light is cast (pun intended) on the subject
