low voltage wire
Can you imagine romex for everything low voltage?! Waste of extra money and copper.
Everything?
No
Certain installations?
Yes...VD comes to mind immediately, and as NM is relatively cheap and readily available...why not?
I recently did some LV lighting in a club utilizing 10/2 MC.
Low voltage is not a code term.
Take a look at Art 411 and its title.
We use that type of lighting systems as the system does have to use pipe and wire, so it has advantages for exposed installations. Another example is landscape lighting, where it operates at 12 V and presents a limited shock hazard, so exposed splices are allowed and the cable can be laid on top of the ground. But once you exceed the voltage/current limits in Art 411, you move into a chapter 3 (pipe and wire- or romex) wiring method.
