336.12 Uses Not Permitted.
Type TC tray cable shall not be installed or used as follows:
(1) Installed where it will be exposed to physical damage
(2) Installed outside a raceway or cable tray system, except as permitted in 336.10(7)
(3) Used where exposed to direct rays of the sun, unless identified as sunlight resistant
(4) Direct buried, unless identified for such use
Also welcome, - Dakins , that stuff looks exspensive. You must have a bunch left over from a job. Other wise why would you want to wire your house with it.
http://www.awcwire.com/ProductSpec.aspx?id=Tray-Cable-600V
