jeremysterling
- Austin, TX
We have had numerous batteries explode UPS, Telco and generator.
Storage battery explosions aboard ship have blown submarines in two!
If you consider that a generator is typically an emergency power source one would consider it prudent to replace the batteries every 18-30 months. Typically we recommend new batteries every 24 months. Small price to pay for reliability.
Now I'm really interested. Please tell me the proper way to handle this.While doing monthly p.m. to the gen. set is how we found it. Washed it down with baking soda water and then rinsed it down. Had to do some repainting. The gen set is still under warranty. The factory tech. confirmed the charger was the cause. They replaced both under warranty
I bought an electric start 8/12kW portable Generac last year at a blue box when we had a power outage last year. A wall wart was furnished as the trickle charger, and the instructions said to unplug it after the battery is fully charged (no indicator of any sort), giving an approximate recharge time of 5 hours or so IIRC.The genny is only a 7kw residential unit...
I have heard of Kirkland batteries but I'm not familiar with them.A Kirkland maintenance-free vented car battery. Group 58, 760CA, 610 CCA.
Am I correct that there are both a line-powered trickle charger and a charging circuit from the generator?
I don't know the answer for certain either... but I can't imagine they'd incorporate two trickle chargers when one would suffice.don't know the answer to that question. (I'm sure someone else here must !)
what's the model # ?
Kirkland is the signature brand of re-branded stuff packaged for Costco.I have heard of Kirkland batteries but I'm not familiar with them.
Any generator that I can remember had a standard alternator on the engine for charging the battery and running the DC systems when the generator was up and running. The utility powered charger is only used while the generator is shut down.
So, as far as you know, there are two charging methods.Any generator that I can remember had a standard alternator on the engine for charging the battery and running the DC systems when the generator was up and running. The utility powered charger is only used while the generator is shut down.
No alternator on the air cooled units.
Here is a thread I found with the same complaint:
http://zillerelectric.com/forums/showthread.php?t=135
If it's like a lawnmower motor, that would be a magneto... and unlikely it is used to charge the battery.Externally mounted, no, it's like a lawnmower, it's inside the flywheel, very low output.
I went there yesterday, and found that the battery (automotive type - correct size and capacity - I provided) had exploded. The case top was in several pieces, and even one side had a large chunk missing. Needless to say, there was electrolyte everywhere.
I call my particular version of this problem (or blessing ) priority-based memory recall conditioning... and the prioritization for most memories is on a subconscious level... I have a real good memory, it's just very short. ...
