Hi,
It is our understanding that if more than one inverter is part of a PV system, then the breakers for those inverters have to be in a (separate) sub-panel. Please let me know if this is correct.
The situation we have is a 400am main service with a breaker panel attached, there is a separate breaker panel connected to a breaker in the main service panel. My question is "could we put one inverter into each breaker panel or do we have to install a new separate sub-panel?" The inverters are SMA 6000US which have a max continous AC current of 25 amps, times 1.25 = 31.25 amps so I need 40 amp breakers for each inverter. 80 amps is within the max backfeed of the main service.
Photo attached of panels
Thanks
David
Thanks
David
