brother
Well, this is mostly to vent. Been working on alot of kitchen equipment lately, and I know the NEC doesnt govern the manufacturers, but it just bugs me when they use the 'egc' as the neutral. Basically, they need a 120/208 4 wire receptacle, (2 hots 1 neutral 1 ground) but they only specify 208 (2 hots and 1 ground).
Internally they use the ground to carry the current for their 120 volt parts. (ie electronic boards etc). Once in a while Ill run into one that has a control transformer in it. but too many times I see where they bond to the ground their circuits.
We have to seperate grounds and neutrals on the load side of the panel, Why is it not enough pressure to make the manufacturers do the same and seperate them??? is there less danger in their eyes??
