1 1/4" in a deep 11B?
I'm thinking I'll start my own forum for people with jobs who are actually busy and get things done during the day and need quick answers, rather than just code book references.
11b is 4 11/16.
if you are at work working, why do you need a forum to tell you if its going to work, just do it.
Here's a 4 11/16 from RACO:
http://www.hubbellcatalog.com/raco/...M=RacoBoxes&P=12842,11454,11455,1181,9206,982
You'd have your answer a lot sooner if you knew how to look up your own problems using a code book rather than waiting for forum responders to answer your question.:roll:
I probably would have had my box punched out by the time you typed your question anyhow...
When you do can I join? That way you can answer my questions while I'm still at work, which by my figuring ought to be around your bedtime:cool::roll:
$2.00 for an answer.
$20.00 for a correct answer :D .
If we gaqve you the easy way out, you'd never pick up the book! So now go read 314 and see if your wire size, and pipe size have a potential fit for the application you are wanting to sell as 110.12 :) .
