Lift Prices
Whatever you do, never, never let the customer rent the lift. You will lose lots of $. They will get some broken down thing your employee will try to fix and lose lots of $. Or it will not be there and they do,t care your worker had to drive 80 miles and you lose 4 hours of his work. They will expect you to do the work for the same price too.
Sounds like that happened to you?
where I havent wanted to either front the cost for the lift, or be responsible for it, I have booked it with the rental co then had the customer call them with credit card to pay for it.
I agree to not let the customer just get a lift, it will be broken, not there, wont fit through the door to get it into the building (this happened), gasoline powered (this happened too), or you will end up with a forklift with a pallet on it (this also happened).
I climbed into a customer supplied boom lift one time and started raising the bucket. When I tried to stop it just kept going up and then it started rotating in circles. I tried the emergency shut off switch but nothing would make it stop. It finally stopped after awhile. They had left it out in the rain overnight and I guess the controls were full of water causing it to have a mind of it's own.
On another job I was up about 40ft. in a boom lift when it just quit. The hydraulics quit working and I couldn't get it to do anything. It was late in the evening and I was working alone and no one was around. It was either spend the night in the bucket or slide down the boom. I decided to slide down the boom.
Usually I will have the rental place deliver and pick up the lift. I charge whatever the rental company charges plus 20%.
Most of the time they can deliver and pick up the lift cheaper than I can do it myself.
If you leave it up to the customer to supply the lift this is what you get.
The rental companies will pickup and deliver for an added fee the longer you keep it the better the deal rental for a week is cheaper than renting for four days.
