James M. Clarke
- Charleston, SC
I am adding some large HVAC units to a building. The facility currently has a 600 amp 240/120 single phase panel subfeeding two 225 amp single phase panels. I have to convert the entire facility to 208/120 three phase to get the total KVA I need for the new HVAC units. Obviously, the original single phase panels could be replaced with three phase panels but is there any use for the existing single phase panels with this new service. In otherwords is there a reasonable way to utililze them for the 120 VAC loads but still allow me to balance the main three phase panel board across all three phases.
Main loads that are not 120VAc are four wall mounted air conditioning units rated as follows:
Compressor Volts 208/230 RLA 13.7A LRA 75A Min Cir. 54.6A Fuse Size 60A
Heat Volts 240 Wattage 10 KW 41.67A
Thanks
Thanks
