ItsHot
 - A little piece of heaven!
Do you think that all circuit breakers should be the bolt in type?
			Why? do you askDo you think that all circuit breakers should be the bolt in type?
Just seems to be a better design. I have run into a lot of burned "stab-ins".Why? do you ask
Good point, which makes me think of knife type switches, that poco use.Most of the 'buckets' in distribution equipment just stab-on to the bus bars. These are
anywhere from 100a to 800a or more.
While the surface area is usually larger with a bolt-on unit than a push in . Why do you claim that the QO is more engineered than anything else out there?I prefer the engineered connection of Square D QO and Cutler Hammer CH breakers over the un-torqued screw connection of an equivalent bolt-on breaker. Yes there are exceptions, like re-used/abused breakers, and the 'generic' plug-on connection that every manufacturer sells.
Agreed. Those two (QO and CH) seem to have less contact area than most stab-ins.Why would a QO be better than a bolt on?
What's the difference between a stab-on breaker on a bus bar and sticking a cord plug into a receptacle?
I have noticed that a large motor load tends to burn up stablock connections so I advise bolt on for motor loads.
