Hello there.
I have a question about switch wiring.
I added a heat tape for a pipe that freezez in winter, and want it on a switched outlet. I also think it should be on a GFI.
So I am going to pull power off another outlet, on a standard breaker, and wire a GFI outlet in with a switch with a pilot light. I don't have the instructions for the switch.
On the switch, there are three bronze screws and one silver.
Two of the bronze screws are labled "+Line"
I'm a little confused on what to do with those.
I believe what I want to do is tie all the neutrals together, run hot to the brass screw on the same side of the neutral of the switch, and send a switched hot (+Line I am guessing) to the brass screw on the GFI.
But then I have a +Line left over.
I don't have a meter handy.
Does this sound right?
Thanks
Thanks
