busman
- Northern Virginia
- Master Electrician / Electrical Engineer
Got a customer who swears the GFCI breaker trips when she shuts off items in the bathroom. Mostly the Fluorescent Light, sometimes the hair dryer, but always when she shuts it off. Any ideas? I was thinking maybe the inductance of the motor/ballast could be causing an arc to ground somewhere. Kinda like when you open the points on a car ignition coil, it causes a momentary spark on the spark plug.
I had planned to:
Check the load on the breaker
Replace the breaker with a non-GFCI unit
Put a temp GFCI on the circuit.
Any other ideas? I haven't come across this situation before.
Thanks,
Mark
I had planned to:
Thanks,
Mark
