If the run is vertical there are requirements outlined in 300.19 for conductor support which could require boxes as close as 35' apart even in a straight run of conduit.
Well dont forget kinda on the vertical riser you also need conductor support which really means a box its not a box per nec its a support at different lengths on your riser going up .
You install a box to install cable or conductor supports we use the wedge type these are custom made when you order them and there made from wood .
These are bushings specially made that each conductor gos thur and are held up by the wooden wedge .
