Marine Electrician
e57
Any Marine Electricians on here?
Not Marines who are Electricians..
Or vise versa...
Not former Marines who are Electricians..
Or vise versa...
I'm one of those... Well at this point I'm both of those, in the formal sense...
But ship-board type - Marine Electricians?
Marine Electrician
I've installed more than my share of brass stuffing tubes through steel bulkheads, along with tinned shipboard cable both with and w/o the braided outter sheath in brass, aluminum and stainless. I enjoyed the work, except for the messy graphite packing.
Excellent!
Excellent!
It seems work on land here is at rock bottom - and for some reason work at the ship-yards here is seemingly booming?
I was wonder how one gets into this area of work, and more about the standards of practice, and obvious differences in wiring methods?
Did/do you like the work, and did it pay well?
Long time ago....after getting out of the Navy (four year "Electrician's Mate) looked into the yard at Bremerton, Washington. Tech's did okay, but the average yard bird (electricians, fitters) only got about 1/2 to 2/3's what union scale was at the time...course that was back in the 80's.
Work has hit rock bottom here as well. I worked on steel hull ships and tugs for a few years, mostly research vessels. Not building them but adding equipment and renovating them, most all were ac, a few tugs were 240 dc. No conduit, all cable, all tinned conductors, many different types of cable, some with a metal sheath that makes it look like an explosion proof flexible connector, some look like residential NM cable. An example of the service on a smaller ship (300' + -) would be a 200 amp, 480 v, 3 phase shore power service through a pin and sleeve connector to three transformers below deck wired delta on the primary and a 240 4 wire secondary, the neutral is not grounded at any point in the system, referred to as a floating ground. Two pole breakers are a must for all 120 v circuits. Any penetrations through a watertite bulkhead must be done with a stuffing tube. Receptacle and switch boxes on deck should be bronze or aluminum, although I've seen FRP, PVC and stainless junction boxes used for controls on hoists and A frames. Lots of systems to keep up with, from basic ventilation of the engine room, to rudder control, to the meat freezer in the galley. The pay was good, not great, then again I'm in Florida. We took a lot of pride doing what we did because we knew the crew depended on our work 6,000 miles away from home. Once a research vessel sets sail from homeport the generators run 24/7, they can't take the risk of damaging sensitive lab equipment or anything else for that matter by tying into shore power at a third world port. These are links to basic parts:
Click here: Manning Product Lines - Pauluhn Electric
Click here: G&B Marine. Catalogs
No links.... :-? I found 'em by name search - Thanks! I has some limited experiance on docks before in the service, some ship to shore (on the shore end), but ships nothing really other than a peek around, or being stuck on them not paying attention...
Thanks again...
