FT switch connections
I wanted to attach a drawing which show how the FT switches have their wiring done to the relay. and i had a doubt on why it is connected that way. please can you tell me how i can attach the PDF
When you're in the post window scroll down and you will see a button to "manage attachments" clicking on it will give you an option to upload a PDF.
Roger
Ft switch connections
i went to the bottom but could see that the posting rules are given as such for me..not sure how to activate that.. kindly help
You may post new threads
You may post replies
You may not post attachments
You may edit your posts
Test Switches
Test Switches
Not every one does it the same but our practice is to mount the test switches under the relay with the connections on the top of the test switch going to the relay and the bottom of the test switch connecting to other devices. The problem with this is that any potential blades will be hot when open. But, this is a matter of experience and expertise. No one except a qualified relay technician should be opening test switches.
