Property manager wants me to quote, from owners request, a new 100 amp panel for each tenant.
I'm not sure what the main service size is. Main riser is RMC measures 3" outside and cloth covered copper conductors.
The main service enters a gutter with five meters- 4plex plus house meter and 4 40amp disconnects feeding apartment fuse panels.
Each apartment only has (5) fuses (2) 20 amp appliance circuits, and (3) 15 amp lighting circuits.
House panel services common boiler, common laundry (washer gas dryer) and common basement lighting.
Owner is considering adding a fifth apartment in basement new meter and panel.
New install would still fall under six disconnect rule, but do you feel that main service entrance conductors are adequate? If I do a service calc. the demand should be OK.View attachment 3669
I'll try to attach pictures.
Thank you
Thank you
