Greetings All,
I have a detail that I use for specifying isolated grounding in audio systems that requires no metal conduit/raceways touch the equipment rack. The rack is grounded via a conductor to the technical power panel. The low voltage audiovisual signal conduits are also insulated via PVC coupler at the rack and go to their respective destinations in various rooms where they terminate typically in a J-box to mount an an interface device (VGA connector RCA's etc). Typically our interface plates are anodized aluminum or stainless steel.
Is there a requirement for the low voltage metallic conduit to be bonded to building ground?
Thanks,
MAcG
Thanks,
MAcG
