800CM
- Corning CA Family Farm since 1942
I need to correct safety problems in a wiring gutter. Rats gnawed (SP?) the insulation from a portion of a 2/0 hot cable at the point of passage just barely above an insulated conduit bushing.
I believe that there is enough slack to raise the cable above the bushing and apply some sort of fluid insulating product.
Cannot tape cable as it touches two others entering the conduit. Could gently separate cables from each other to apply a liquid or paste type product all the way around the damaged cable.
Would appreciate advice on products to renew the original
insulating qualities over the bare area which is about one inch long and not quite half way around the wire.
Thanks and appreciation,
800CM
800CM
