I am looking at installing inter-tie smoke alarm system in an occupied old multi story house.
Wood framing, insulation, Lath and plaster with wood blocking etc.
The residential standard here in Oregon is 120V 3 wire 14/3 to each smoke alarm unit.
I would like to avoid dust and unnecessary cut-in 18cuin 3/0 boxes.
Years ago in Philadelphia I used to install intertie smoke alarms in old brick row houses with a now retired electrician. He had a small "fire panel" he used for residences and I cant remember the brand. It ran off low voltage cable like commercial fire alarm panel. All this unit had was a battery back up and a 24VDC power supply. Then 4 wire red 18-4 daisy chained to low voltage smoke/alarm heads or heat detectors/alarm heads. very simple.
I would like to find a similar product.
Any thoughts?
Thanks in advance
Note I do not want to install a commercial fire alarm panel in the house.
Any thoughts?
Thanks in advance
