sparkyway
- South Central Ky
Got to settle this issue with my contractor friend...Using a 208 volt 3 phase system...will the lighting neutral load balance out if (for example) I run a black phase (to carry 9 amps) and a red phase (13 amps) with a common neutral. There isn't a need to include a third phase in the conduit for load concerns. I appreciate the technical insights in this issue and I apologize if its a repeat question ( I did check ). Thanks
