PetrosA
- Lancaster, Pennsylvania
I recently had a customer who got a new kiln. It's a professional version, 240V 1 phase to be fused at 80A. Her last kiln died, and that producer tried to blame it on the #2 AL feeders to a 100A disconnect in the kiln room (it had #6 CU from the disconnect to the 50A kiln recept). This producer insisted on #4 CU from the panel to the kiln, and kiln is direct wired. Due to this company's being so adamant about insisting on CU, the customer is now questioning whether the AL riser cable that someone from my company put in years ago wasn't the culprit on the one hand, and also wondering if this new company isn't full of it by making her pay for new CU lines. Is there any basis for insisting on CU vs AL in this kind of installation? All cables were properly sized at all times. I explained that properly sized, either cable should work fine and pointed out that our POCO uses AL triplex to feed her AL SEU to the meter, which then feeds AL to the panel.
