Existing wiring to detached garage are 2 runs of 14-2 UF on a singe 15A breaker. No ground rod. This runs lighting, one GFI outlet, garage door opener.
A new 100A 120/240 panel, 4 wire + ground rod, is being added.
Can the existing system be left as is? The goal is that the 100 panel (running all the tools in a welding shop) can be turned off with the 100 A main and lighting, opener, and say block heater/ batt charger, can be left on.
