buldogg
- Green Bay, Wisc.
On a different forum there was a question if the UL listing of a receptacle would be voided if tape was wrapped around the terminals. What is the consensus here?
I very rarely do it, however, my vote would be no. It is not a permanent change to the receptacle. IMO, it would be no different than putting tape on a wirenut. Again, something I rarely do.
UL said:. . . Unless UL evaluates a modified or rebuilt product, UL can neither say that such changes "void" the UL Mark, nor that the product meet's UL's safety standards.
nahhhhhhhhOn a different forum there was a question if the UL listing of a receptacle would be voided if tape was wrapped around the terminals. What is the consensus here?
Monday's code question and answer:
I sent a note to Charlie saying that I don't think he actually answered the question and I don't see a code or listing issue with applying the tape.Monday, September 21, 2009 Subject: 120 volt outlets
Is it okay to rap electrical tape around the terminals when installing receptacle outlets. I am asking because I used to do this and was told by an inspector that this practice voided the UL listing.
Thank you
Dan
Answer:
Hey Dan,
Good question. The device was not tested or evaluated with electrical tape applied. I?m also sure the manufacturer instructions do not require tape to be applied.
Section: 110.3(B) Source: Charlie Trout
This was in NECA's code question of the day today.
If wrapping tape is a violation, then would replacing the 6/32 mounting screws with something else be a violation?
When I mount devices in handi-boxes, I find the 6/32 screws are too long and will hit a connector that's been installed. I take the screw out and shorten it to prevent this.
I hope the UL police doesn't come and arrest me.
"Bad boy, bad boy, whatcha gonna do? Whatcha gonna do when they come for you...."![]()
Hey, free health care, plus three hots and a cot!![]()
Getting the former ain't worth putting up with the latter for.And a new friend named Bubba.![]()
I would not rely on the tape to hold the wire in place against the terminal. How much time is it going to save you? You have the screws, why not use them?![]()
Your joking I hope
I have used it where JEM boxes are used, as the screws on a receptacle can contact the sides if slid over in the slotes, espeically when #12 is under the screws.
