daveselectric
- Ohio
How would one wire a relay to disconnect power to a receptacle. The relay would be operated by a micro switch from a fire supression system? What material / products would be used?
I like RIBs for some applications, contactors for others. Grainger sells a couple of the RIB models.What material / products would be used?
How would one wire a relay to disconnect power to a receptacle?
It does. I've used them often in fire-suppression wiring. They attach directly to an existing box with a 1/2" locknut.If I remember right, RIB stands for "Relay In a Box"?
