Wiring a relay for receptacle
daveselectric
Ohio
How would one wire a relay to disconnect power to a receptacle. The relay would be operated by a micro switch from a fire supression system? What material / products would be used?
If the relay itself can handle the load, use the microswitch itself.
If not, run power through the microswitch to the coil of the relay, and the power for the recep through the contacts.
I like RIBs for some applications, contactors for others. Grainger sells a couple of the RIB models.
Those are pretty neat. It looks like it saves a mounting enclosure at the least.
I think I've seen Iwire mention these before. If I remember right, RIB stands for "Relay In a Box"?
Steve
How would one wire a relay to disconnect power to a receptacle?
Is this for when a potential switch is brought into a console or some other re-located "something?
Or does the use of this RIB present an over-ride to the switch, thus being a killed thus a dead switch.
Or is this Rib act as a controlled N/O or N/C contactor?
Frankly, I'm just trying to gather exact thoughts of these applications; I understand my first question but can't wrap my mind around the second two.
Thanks in advance!
I forgot to read the overview...
It does. I've used them often in fire-suppression wiring. They attach directly to an existing box with a 1/2" locknut.
The ones I get from Grainger have dual-voltage control (24 and 120vac) and 20a SPDT contacts, and an LED on the box.
