And what do you expect UL to do about it?
Lemme guess: That's a picture of a polar bear in a blizzard.Here's what it looks like after the drywallers and painters have finished, and just before you install the receptacle:
Now where the heck did that outlet go......
For those they can't figure out how to RTFM :roll:...
Here are some images:
Product Installation
http://www.bocci.ca/#/22-instructions/
et al.
While appealing to the eye....it looks like a collassal PITA....from install to troubleshooting/repair/replacement.
I did not see that it was or is available as Tamper Resistant.
not much different from "walker" duct.
I think this manufacture and their web site should be reported to UL.
406.9(A)
Is a wire considered to be a 'fixed grounding pole'? Remember, this is just a receptacle, not a GFCI.
Just think of the poor sap that gets called to work on one of these and has never seen them, thus has no clue about the special tool needed to remove the receptacle.
Since a special tool is required and there seems to be no indication of the manufacturer visible on the receptacle, let alone any indication for the requirement of a special tool to be used, I would consider the interior of the box to be non-accessible.
So lamps should be outlawed as well? When you look at one, it's not obvious how to remove it.![]()
I have never met a fluorescent tube I couldn't conquer.
You da man! :grin:I have never met a fluorescent tube I couldn't conquer.
