al Senior Member Location Minnesota Sep 27, 2009 #1 For 70E direct contact phase to phase and phase to ground voltage measurements who makes instruments for this??
J jim dungar Moderator Staff member Location Wisconsin Occupation PE (Retired) - Power Systems Sep 27, 2009 #2 al said: For 70E direct contact phase to phase and phase to ground voltage measurements who makes instruments for this?? Click to expand... What voltage range are you looking for?
zog Senior Member Location Charlotte, NC Sep 27, 2009 #4 al said: Voltages would be 13.8kV and 4160 volts Click to expand... I use a biddle detex (Hotstick mounted of course) for thiode voltage ranges. Be sure to order the pizotest tester with it to verify your meter on a known live source before and after each test.
