Hello all,
Can someone explain the concept of a back fed main? Aside from the basic concept, I will provide my situation.
I have a main/service panel that is a 100A and a sub panel that is a 125A main lug panel that is fed from the main with a 60A breaker. The sub panel now has 8 breakers and code says it has to have a main breaker because it is over the 6 limit. Also can someone give the article number for that? The sub can be converted to a main breaker but only with a 125A breaker.
Also, when using a back fed main, it requires a hold down kit...why is that? I noticed the service/main panel breaker has a hold down kit as well.
Thanks,
Mka
Thanks,
Mka
