- Windsor, CO NEC: 2017
- Hospital Master Electrician
Does a 70W MH ballast have to supply a 70W MH lamp? What happens if you were to use a 60W or an 80W MH lamp?
Yes and No, depends upon the ballast, many are now multi watage, I have seen magnetic for 50/70w, and electronic go from 35 to 100 wattDoes a 70W MH ballast have to supply a 70W MH lamp?
never seen a 60 or a 80 watt, but the example is the same, in a case where the lamp was higher then the ballast rating, the lamp wont last for very long, in the case where the lamp is lower then the ballast, ballast won't last.What happens if you were to use a 60W or an 80W MH lamp?
Yeah, I was just mostly throwing that out there as a frinstance.
I encountered a bunch of dead ballasts with 50W lamps and 70W ballasts, and my supply guy was incredulous as though I should known that from day one. I advised the customer to go through and check the lamps before it started tattooing more ballasts, but somewhere deep down I was wondering if the supply guy was absolutely right or not.
No - there is a subdivision started a few years ago. Basically, monument signs were erected, a few houses were plunked down, and then the market crashed so building ceased. The company taking care of HOA property care and maintenance called us to fix some lights that were out, and that's where I entered the story.Were these fixtures he provided for a new job that you installed?
Man, it's nice to see in any neighborhood. We need some of these "green shoots" to get growing.It is nice to see building resuming in the neighborhood in question, though.
Well I'd say he's the stupid one.Edit to add: The reference to the supply guy was just me asking the stupid question of him that I asked of y'all when starting the thread - his reaction indicated that it was a stupid question and I should be ashamed of asking.
LOL, I don't always believe the supply guys either. There liability is usually to replace the part, that's the inexpensive side.I don't always believe supply guys, so I figured I'd ask here and check his facts.![]()
As long as we're asking stupid questions and giving stupid answers I'm going to make a stupid assumption:roll:. I would think that a ballast that is rated for a specific wattage bulb (say 70 watts) would be able to handle the illumination of any wattage bulb up to the wattage that is being demanded (say 50-70 watts). The wattage of the bulb determines how much power is required to drive it. By the same token, if a higher wattage bulb were installed (say 80-100 watts), the wattage capability of the ballast would not be enough to illuminate the bulb and eventually burn out the ballast while it continually attempts to light a higher wattage bulb.![]()
