jaylectricity
- Massachusetts
- licensed journeyman electrician
Sometimes you are asked to fix a small problem in the simplest way possible.
Problem: Metal single gang, old work switch box hanging free through a hole in the sheetrock that is slightly too large for the ears at the top of the box to grab onto. Box is in a closet, out of sight and rarely used.
Creative solution: Cut down a holding strap (Madison bar, etc) longer than the horizontal measure of the switch box ears. Use that to straddle the surface of the sheetrock on each side of the box behind the ears of the box.
Is there anything wrong with this installation? (quick and dirty Paint drawing)
Also, please share some creative solutions to problems you've had.
