Looking to upgrade 100 amp service to a 200amp, the
Old screw type fuse panel with knob and tube. Yuck! Right!
Anyways, the existing service meter was once on the front of the house but there has been a small garage attached to the home and now the service meter is hidden inside.
My question is-?
Would it be allowed to Install the 200a meter on the side of the garage (approx. 12' away) with new riser and wire, then straight out the back of the meter with rigid conduit over to an LB into the back of the new 200a main breaker panel which of course replaced the old screw type panel, or is there a problem with the distance from meter to panel?
Am I even on the right track here?
any info would greatly be appreciated.
Thanks, Trigger
My question is-?
Thanks, Trigger
