brantmacga
Señor Member
- Georgia
- Former Child
I don't know how to explain this in a short manner, but I'll try.
Service call for tripping breaker and partial power.
I traced the tripping CB back to a switch box in the living room, and disconnected the incoming power to that box. POCO came out for the partial power issue and found a recent gas line installation had resulted in a cut in the lateral. While the POCO was replacing that lateral, the bulbs in a chandelier started fading on and off.
Here's what I have so far;
House is approx 20 years old, built for an electrical contractor and wired by his company. The living room has 22 switches. Almost everything in the house has a 3-way and many 4-ways.
The ceilings are vaulted and there is no direct access to the cables for a visual trace.
Many fixtures are wired with a single bulb on its own switch and the rest of the bulbs light by another switch.
A little under 2k feet and there are at least 100 switches.
I found a traveler on a 3-way connected to the tripping CB has a short somewhere, but have yet to identify what that switch controls. As you can imagine, its a process of removing every device and fixture and ohming out what goes where.
Now, the cable I disconnected to this switch box came out of a fluorescent light in the laundry room; I have attic access there. The fixture is being used as a JB. Once I disconnected that cable, the laundry room light started working again. Since disconnecting the 3-way traveler with the short, it no longer works, and I have 120v on the neutral of the disconnected cable. The chandelier also has a loose neutral; I have 120v w/ no bulbs in; install a bulb and it drops to less than 5v.
I cannot understand how disconnecting that traveler started this snowball.
I have checked continuity on almost every other 3-way I could find and have yet to find the other end of it. It may be safe to assume that this traveler is broken completely into and is grounding out on the bare wire in the cable.
The only thing I haven't got to yet is grounding the other traveler and trying to find it elsewhere. We ran out of time and I have them rescheduled for Wednesday.
Anyone have an idea for some other starting points or something to look for. I know I'll find it; just looking for something to reduce time.
thanks,
b
thanks,
b
