dswilliams
this is in a plenum
this is in a plenum
May be MC.Is that 3/8" FMC coming in from the upper left feeding this conglomeration of power supply's?
They're labeled as RIBs, even though they look like transformers.Couldn't you have just bought a 5-channel power supply???!!??
I like the built-in breakers. I wonder if they're in the primary or the secondary.RIB makes transformers or at least labels them. http://www.functionaldevices.com/pdf/TR75VA002.pdf
Relay In a Box. Check out Bob's link, remove the extra stuff from the URL, and click on 'relays.'RIBs?
3/8" FMC can not feed an outlet box. 348.20(A)(1)-(5)
Possibly 300.22(B)
I don't see wher this section restricts a receptical suppying plug in utilization eq.
