Microwatt
- North Dakota
Here is the story. Health care setting. The campus has two generation systems. One system is (4) 2MW gens that parallel up to provide power for the hospital, clinic, and some support buildings. It is primarily used for peak shaving. The other system is (2) 1.2MW gens that are used as the emergency system. Here is the problem. There is a mobile ultrasound machine that will not work in one wing of the hospital when the 4 2MW gens are on-line. The power supply relay just chatters and the unit won't power up. If we transfer that wing to the emergency generators the unit works fine. Also, everything works fine when on utility power. Any suggestions?
