codewarrior321
Hi I hoping to find out the formula to go from Kwh peak usage in a month of 2,706 KWH to actual amperage usage in a church ( single phase 240VAC) and peak usage in a month of 9,200KWH in a liquor store to actual amperage (3 Phase). Question is I want to find out if I have to upgrade on either service to higher amperage load center. Church has a 240 VAC delta 3 phase service which means that b phase can not be use for any 120vac load. the liquor store is 3 phase Y service which everyphase can be use for 120vac loads.
Thanks for comments.
