mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2023 NEC
One persons logic is not anothers.
The code has to do what it has to do, the NFPA is not concerned with the enforcment angle.
As far preventing what a hack and a homeowner may do ....
Make something idiot proof and someone will make a better idiot. :grin:
I stole this from a previous thread because it did not want it to run on.
I agree with this however would it not be a good idea for the NFPA to give at least a little thought since fire prevention and safety are their goals?
I am refering to the example in a previous thread http://forums.mikeholt.com/showthread.php?t=118464 where a bathroom was beign remodeled. A receptical had to be added however the existing circuit was only 15 amps. So the entire circuti has to be redone even though a new circuit is not needed just and additional recep on the existing. The issues is the professional electrician has to follow the code which will cast more while a non professional can do a safe job costing much less. If the cost difference is $60 vs $1000, and both are equally safe, wheres the incentive for the home owner to hire a licensed professional?
