I'd like to meet the knucklehead who decided it would be a good idea to put THHN on plastic spools.
I'd like to meet the knucklehead who decided it would be a good idea to put THHN on plastic spools. One slip or fumble and the entire spool is rendered practically useless. I want to give a him bill for all the wire I've wasted.
I'll gladly pay an extra dollar or whatever to have THHN on metal spools again. Not only that, metal spools are recyclable. Those plastic ones are not.
You might remember I had to repair a few spools at Jo-Anns. Couple of 4 11/16" blanks and some 3/8" threaded rod.
Yes the broke spools are a pain but..... I want the guy that designed the old GE panel covers. The type that you loosen the screw and then turn the ring to rotate the clamping ears on the back of the cover that weighs 200lbs.![]()
You can make something like this with sheet metal discs, 1/2" emt, 1/2" fittings on the ends, and 3/4" emt in little segments as bushings to fit the rolls without slop, to space them apart, etc.Rack a Tiers makes these, kind of pricey like $30.00, you need to put them on before wire gets too skanky
I haven't seen a wooden 2500' spool in a long time around here. When they first started using plastic for the 2500' spools they were junk and I would refuse delivery if the supply house sent my wire out on plastic spools. About 4 or 5 years ago, they redesigned the plastic ones and they hold up as well as the wooden ones.They do make 2500' reels, and they're usually wood.
That's a great idea, even for unbroken reels.. . . 3/4" emt in little segments as bushings ... to space them apart, etc.
That I've been doing for, well, forever.. . . every other roll on your homemade wire caddy should spool off in the opposite direction to keep everything pulling off nicely.
That's true enough. It does, and she does.As with any wire caddy, this whole thing works better if you have a helper who knows what he is doing.
...every other roll...should spool off in the opposite direction to keep everything pulling off nicely.
That I've been doing for, well, forever.![]()
I'm all for the same direction... My rack doesn't have spools next to each other to drag other spools with it wel only one or a few are going - so it matters little which way they go.If you make this thing with several spools, every other roll on your homemade wire caddy should spool off in the opposite direction to keep everything pulling off nicely.
