iMuse97
- Chicagoland
I repaired a UF line to a lamp post today.
At the post I tested 37 volts line to neutral and 37 volts ungrounded to EGC, and 0.0 volts neutral to EGC.
Turned off the feed, dug in three locations, found the fault and repaired it.
Lamp post contains a 35w HPS lamp with appropriate ballast. The lamp strikes and warms up, but does not remain lit for longer than three or four minutes. After that it does not restrike, as long as I was there (about a half hour).
My question is:
Would running 37 volts to that ballast and lamp for several months ruin both of them? or only the ballast? or only the lamp?
My question is:
