Peace to all!
I have a residential house customer that wants to increase his service from 200A to 400A. His meter base will be about 15 plus feet from the new panels. Here are my thoughts on the issue. Since the meter base and panels are farther than 6 feet apart, a 400A service disconnect switch would have to go between them. Also, 200A SER cable would have to be run to each panel from the disconnect. Also, I believe that each panel will have their respective grounds and neutrals separated and everthing bonded at the disconnect. I am correct in saying that the green bonding screw will not be installed at each 200A panel? I live in VA.
Thanks to all that reply and may you all be blessed, I know I am.
