The Pushmatic breakers aren't necessarily unsafe. They do have one drawback in that the original ones only have thermal trip mechanisms and do not have an instantaneous magnetic trip mechanism. In real world terms that means they won't react quite as fast in the event of a short circuit, but their overload response time is average.
The main drawback is that old ones tend to fail mechanically, ie they won't reset after a trip or if you turn them off. So far I have only seen and heard of them failing "safe", as in not turning back on as opposed to FPE and Zinsco which stay closed into a fault. :grin:
The little "on/off" indicators also go bad and stay stuck in either position or just rattle around loose.
UBI makes replacements (at $40+ EACH for single pole) which seem to have more robust mechanisms, but I don't know if they have magnetic trip added to them.
How about some pushmatic switchgear?
I think this has finally been torn out but I had made a few service calls to this gear. This is 3 phase Pushmatic, very odd phase arraignment.
I like the LB under the circuit breaker enclosure at the right, & the fire exting. is in such a accessible location.How about some pushmatic switchgear?
the only problem I know of with them is that they are getting harder to find replacements.
I've actually seen these breakers sold at Home Depot
I dont know why, but something about that picture makes me think i would use a long stick to operate any of the breakers in that gear.....
Hello, does anyone have information on the old bulldog push amatic circuit breakers. I have a home 13000 square feet that has five of these 1950 plus circuit breakers. Does anyone have info telling if these CB's are safe.
