kevn96
- JoDaviess County, Illinois
What is the best way to pull 4/0 4/0 2/0 AL cable 400' underground? Should I go to 2 1/2 pvc to ease the pulling? It is in a straight line.
Is this a jacketed cable?
Hi Kevin,What is the best way to pull 4/0 4/0 2/0 AL cable 400' underground? Should I go to 2 1/2 pvc to ease the pulling? It is in a straight line.
Isn't that redundant?That was "Rural residential" rbj
You called it a 200 amp underground pull 400 feet long with 2- 4/0 & 1- 2/0 aluminum in PVC but you don't mention an equipment ground.
Isn't that redundant?![]()
