jaylectricity
- Massachusetts
- licensed journeyman electrician
Normally the HVAC guys that I have worked with will hook up the thermostat wiring if I run it for them. The few times I've done it myself, I've been able to look at the schematic and figure out what goes where. Until today. I'm hooking up an A/C only, compressor outside the residence, air handler in the attic.
The schematic shows all the field wiring then shows the wires that go out to the thermostat and the compressor as a block of wires with a nice handy label: "low voltage field wiring". No symbol representing a thermostat, or a compressor. In fact, it just shows the leads, it doesn't show where they might go.
There is a wire harness in the air handler that contains the leads I can splice to my thermostat wires. A red wire, a blue wire, a green wire, a yellow wire and 3 white wires that terminate on another wire harness. They don't seem to do anything. I ran 18/5 to the thermostat (colors: red, blue, green, yellow, white) and 18-2 (red, white) to the compressor. I haven't connected the thermostat yet but I tied all three reds wires together, then color to color, leaving the white ones alone.
I studied the internal wiring to get an idea of the flow of electricity. Am I going to blow this thing up?
