midnitel
- New Jersey
We charge $240 for fan without light kit, 280 with.
Bonus question along the lines of the OPs........
Who here will balance a fan?![]()
I could do a ceiling fan replacement for $150 but I won't. So instead- existing fan rated box is $300. I don't care what other guys hang fans for around here. You called me and that is my price. On another note, ceiling fan installation is pretty much a drag for me. I did not spend my years training just to look forward to getting the chance to go hang one of those. But if you really want to pay me what I want to do it, I guess so, ok I'll come do it...... You don't have to actually say all that to a customer, but if you think like that your life will get better. I never have had real slow downs, and the economy sucks here too fellas.
$125.00 Fan install with new fan rated box.
Extra if conductors are short....
We do NOT balance fans...No way...
Is this to be balanced on:
ones head
ones finger tip
or
ones foot, like a soccer ball
...........I'll be honest, I wouldn't even know what to do with those little weights that come with the fans. I would be curious to see if there was anyone that had the patience to mess with them.
It could take hours to balance a fan!
what a pita
what a pita
not if I'm balancing it. A push on a blade here a time or two, if that doesn't work put the fan on a lower speed and show them the balancing kit and the paperwork. That's all the patience I have in the balancing department. I know the supporting box is installed well before I hang the fan. I didn't buy the cheap fan and I'm not going to balance junk some clown bought somewhere other than where I recommended. If they think a quality fan is to much money they certainly can't afford to pay me to make it something it's not.
I've probably hung a thousand fans in my career, and have used those little balancing kits that come with the fan exactly zero times. I always....
-Make sure the blades are tight and at equal angles.
-Don't hang super cheap fans.
-Don't drop the fan motor on the floor.![]()
Every time I've done those three things I have had close to zero wobble.
I can say ditto to this and add..... always start with a securely mounted fan rated box.
As far as cost to R/R a basic fan anywhere from $175-$225
Done it many times.I would be curious to see if there was anyone that had the patience to mess with them.
I have had problems with Hunters before. It is usually warped blades instead of bad weights. Hunter will send free replacement blades.Every Hunter fan I install comes with a kit, and I doubt I've ever had to use them on the Hunter.
Agreed if it is a weight issue.Then you're doing it wrong. 10 minutes. 15 tops.
