hockeyoligist2
- close to greenville sc
I have someone wanting me to install a thermostat on gas logs. Actually a cast iron heater with gas logs inside. New install, but not by me. It has a flame adjustment but no actual thermostat for room temperature. It has an on/off switch which toggles between pilot and the flame. It has a set of wires (tied together) for a remote control on/off switch.
They want something simple so it will cut on/off because they are old and have to get up to turn it off and on. And they don't want a remote because they will wake up hot or cold.
Will I be in violation of any codes by installing a thermostat next to or on the heater? It will not be accurate for actual room temps but they can adjust it to the temps they are comfortable at. That is what they want. They don't want me to drill holes in the fireplace and install the thermostat in a location that would actually control room temperature.
In other words they would have to kind of fool around with it to get the setting they want since it will be warmer at the heater than the actual room temp.
