sparky 134
- Joliet, IL
A customer called asking about some type of meter that could be installed to measure usage. The setting is a 6 unit townhouse with a common water meter closet on the end unit. The receptacle inside the water closet which provides power to the heater in the closet is fed from the panel located inside the end unit thus the homeowner has been paying for the power for the heater.
So the homeowner wants some type of meter to measure the amount of power the heater is using so he can divide the cost by six and have the other units reimburse him. I suggested just using a flat rate per unit for reimbursement but he didn't like that idea.
Any suggestions ? The heater is a small, plug in, 120volt unit.
