Sierrasparky
- USA
- Electrician ,contractor
Not that bad an option.The water closet only contains the six water meters for the six units. The main water service to the building is located in this room and it feeds the six separate meters.
Since this closet is located on the side of the end unit the easiest solution to heating the space was to tap into the end unit's HVAC system. How the builder got this past the Building Dept. is baffling.
As for bringing in a separate electrical service to provide power for one 20amp receptacle for the heater I know the association would never go for it. The costs would be very high.
I'm not sure how many of these six unit buildings are in this subdivision but there are at least twelve of them. The Kill A Watt plug in meter would be the simpliest way for them to monitor the usage but then the HOA would have to read each meter once a month, calculate the usage, figure out the cost, pay the end unit homeowner, charge the other five homeowners. Quite the project.
Here is the bigger problem. If that unit's power is ever off for what ever reason then the pipes could freeze again.
If this was in California and the building is less than 10 years old and this problem recently cropped up. That builder is responsible. check with the local AHJ.
