tim89s
- Brush Prairie WA
I need to feed a 208v 50 amp 3 phase load via cable tray. Actually, I need to feed about 80 different pieces of equipment from a cable tray but, I just wanted to throw out one example. After reading the code here is what I came up with. I will run TC cable from the panel through the cable tray until I am above the piece of equipment. I will then set a box on the side of the cable tray and run the TC cable into it. I then plan on dropping SO from the box with the appropiate cord connector. After reading 400.7, I am thinking I need to install a receptacle in the box and have the SO plug into it. I would of rather hard wire into the box, am I missing an exception or other code that would allow me to do that. Also, can I attach a support grip to the cable tray for the SO? If not how would I support the SO in accordance with 400.10. Thank you, Tim
