I have a small project installing a connex box with the following installed inside. A 3 phase 480 volt panelboard, a small transformer for a sub panel 240/120. and some misc motors and compressors. My question is that the connex will be fed from a generator installed next to the connex, all of which will be use for about a year. What are the grounding requirements and the requirments for bonding the generator grounded conductor. Since this connex will be fed from the generator there will be a provided 3 phase 5 wire pin and sleeve male connector from the main panelboard for plug in to the generator.
