I have several problematic installations of low voltage lighting transformers where the GFCI nuisance trips. Here are some questions related to that. (Note - the installations are in coastal Florida)
1. Can inrush alone trip a GFCI? Note that the transformers involved carry loads varying from 800W to a 1000W. Also note that the addition of a 50 ft. extension cord between the GFCI and the transformer seems to prevent the GFCI from tripping - though not always.
2. Could electronic noise from the soft-start unit in the transformer cause the GFCI to trip?
3. Would a panel-mounted GFCI breaker at the mains panel be less problematic than using a GFCI receptacle near the transformer (outdoors)?
4. What is the absolute best, most robust outdoor GFCI receptacle?
Thanks for your help.
