Does that mean I can plug my speakers directly into that recep?![]()
Been there done that :grin:
The internal components are really no different then more expensive receptacles you can buy from a hardware store. The difference being that they are brass and gold plated...
Nope mxslick is right about the spelling. It is bass not base....![]()
And they are "AUDIO GRADE" :roll:
Yeah, once.Yea go right ahead. they'll play old smokey. :grin:
Don't forget to bring up skin effect.I would not use the solid wires as they are just not as good:grin:
The stranded are 5 times as much and you can charge the extra to the stupid customer.
(Kind of like dropping a V12 engine in a Ford Tempo?)
Completely out of this world
Monday, October 26, 2009
Daniel Jackson from Cheyenne Mountain, CO
Before installing the Wattgate 381 Audio Grade Duplex Socket, I was only able to pick up a few local radio stations on my HD receiver. The stations I could hear had a lot of static and where hard to listen to. Since installing the Wattgate 381 Audio Grade Duplex Socket I can now pick up nearly ever station on the planet and even a classic rock station from Alpha Centuari system.
The 25% increase of amperage as well as the power sine wave interpolation without a doubt prove that the Wattgate 381 Audio Grade Duplex Socket is worth at least five times the full retail price.
After some calculations I have determined that if were to use the Wattgate 381 Audio Grade Duplex Socket to recharge my Prius, I will obtain close to a 35% increase in mileage using batteries alone.
I further hypotheroize that if one Wattgate 381 Audio Grade Duplex Socket was installed in every household in America the global carbon dioxide levels would be significantly reduced.
G0049 said:Does that mean I can plug my speakers directly into that recep?
Monster Cable could make a killing if they made their own "audio grade" NM cable.
Heck, they already make dryer cords.
They are only 40 bucks and may even serve a purpose in a harsh environment. However......if the brass on your dryer plug is corroding enough to make even a smidgen of difference maybe you have bigger problems that need to be addressed??? :roll::roll:
